how to control esp 301 motion controller using labview with mouse?
I want to use mouse movement to control the ESP301 motor within labview code, I do not know how to deal the problem?
The function should include: scroll control z axis motor, drag displacement control the x ang y axes motor also can define the move speed. Could anyone like help me? Thanks.
The attached file is my reference file when move the mouse the x and y motors will stop suddenly. I donot the reason.
(3,702 Views)
Hello xgsheng,
Unfortunately National Instruments does not support the Newport ESP301 Motion Controller drivers. If you believe there is a problem with the sub VI's, you may want to direct your questions towards Newport Support.
As for the sudden stopping of the x and y motors upon mouse movement, that seems like it could be due to a logic problems within your code or some other bug. I suggest using highlight execution or probes at points that might be causing this problem.
Spencer R.
(3,657 Views)
