07-02-2009 10:38 PM
I am using BNC 575 pulse/delay generator, how can I generate two pulses in one channel, the pulse width is 1.5us, the distance between two pulse is from 0 to 10us.
Thank you very much.
07-03-2009 06:22 AM
09-20-2010 07:54 AM
Hi
Can you help me in connecting bnc delay generator to labview ?
09-20-2010 10:59 AM
In LabVIEW, you can use Tools>Instrumentation>Find Instrument Drivers. It would have downloaded the driver here. The main Instrument Driver Network has links on what a driver is and how to use one.
08-01-2013 03:24 PM
There are several ways.
I am assuming that you want 2 pulses for every internal or external trigger.
The most flexible solution if you want 1. an independent delay between the trigger and the first pulse and 2. between the first and second pulses and 3. with independent widths for each pulse: Sum the timing of two channels and to present the timing onto one of those channels.
If you want just two pulses of the same width you can have a burst of 2 pulses.
The trigger source you use can also be the sync source. Contact yee@berkeleynucleonics.com for more help.
