hi, actually i want to save labview code as a pdf file to prepare my documentation is it possible to save in pdf formate?
hi, actually i want to save labview code as a pdf  file to prepare my documentation is it possible to save in pdf formate? please reply me soon..
thans in advance.
(3,046 Views)
Hi vrsiddartha,
The standard print outputs from LabVIEW are:
Printer
HTML File
Rich Text Format (RTF) file
Plain text file
These can be accessed via File -> Print. Although there is no direct export to PDF option there, if you have a PDF plotter setup in your list of printers you could use that to create your document.
Hope that helps.
The day is quickly coming when every knee will bow down to a silicon fist, and you will all beg your binary gods for mercy.
(3,041 Views)
Accepted by topic author pavithralingareddy
When you print a VI, you can choose to print VI documentation, and print it to printer. If you install PDF printer, it'll appear as a selection. PDF Creator is one of free PDF printer you could use.
(3,038 Views)
thans for your reply. i got it.i downloaded ... BullzipPDFPrinter_9_10_0_1629_S.. so that i can save in pdf formates
(3,035 Views)
