12-15-2011 01:45 PM
Is there a drawing, or any other info, of the GPIB-140A that shows the location of the mounting points and screw size? I've looked thru the user manual to no avail. I want to mount several units to a panel, and need that info. I don't have one on hand, so I can't make measurements. Thanks.
Solved! Go to Solution.
12-19-2011 12:33 PM
There is a drawing, I am getting in touch with some folks at R&D to see which specs I can release to you. Thanks!
12-19-2011 02:27 PM
I've attached a screen shot which may be helpful to you. Thanks!
12-19-2011 02:31 PM
Thanks Pete! Exactly what I needed!
Leo B
12-19-2011 02:34 PM
You're welcome!
