04-20-2015 04:02 PM
Hi
can anyone provide a simple working example of RS232 setup parameters, and a command like *IDN?.
I want to verify the communication setup, but it's not working correctly.
The RX symbol is blinking on the E4418B whenever i send a cmd, but it's not reacting otherwise.
If i send the *TST? cmd, i would expect it to run the selftest.
When i send a MEAS1? cmd, do i have to do anything further to get the result ? like read some output buffer, or is the result send directly to my terninal program ?
br
Nikolaj
04-20-2015 04:15 PM
04-21-2015 06:00 AM
is must be something with the comm setup.
I changed from "putty" to "termite" terminal and setup in same way.
However now it's working like i expected.
There must be something "hidden" in the "putty" tool
04-21-2015 08:02 AM
Hidden?
More like you didn't configure Putty properly.
04-21-2015 04:19 PM
Yes... hidden means just that
04-21-2015 10:04 PM
If you say so.
You might as well give up.
