12-28-2010 02:15 PM
Do you mean that i had to create a win32 console application and add the .c and .h files and then run the project???
thanks
12-29-2010 09:03 AM
Hi Ala Ayesh,
The instrument driver is in C, you will need a C compiler to compile the mxox802x.c (not the mxox802xu).
Then have that DLL placed in the same folder.
Hope this helps!
12-29-2010 09:20 AM
Dear Mr.Christopher,
thanks am sorry to bother you a lot.
but can you give me a name of a c compiler to use, because i tried many ways to convert a .c file to a dll with no luck at all
i appreciate your help
thanks a lot.
Ala Ayesh
12-29-2010 10:59 AM
Hi Ala Ayesh,
I used LabWindows/CVI to compile the dll, make sure that you are only compiling the mxox802x.c and not the mxox802u.c (This references CVI specific functions).
Hopes this helps!
01-02-2011 03:35 PM
Hello again,
i still have the problem but now with an error message of
"can not find entry point "mxox802x_init" in mxox802x_32.dll"
i read that it is related to dllexport because it is a c dll and am trying to reference it in vb????????
did you get some thing like that?????
thanks.
01-03-2011 01:29 AM - edited 01-03-2011 01:30 AM
sorry to bother you again
it seems we are going toward a solution but the problem now is that it says there are no entry point in the dll and i think it is related to the created dll using labwindows/cvi
because when i created the dll it says dll with no exports won't have imports and so i can't import the dll functions on my application.\
so do you know a solution for that ???
please help
looking forward to hearing from you soon.
thanks.
01-03-2011 01:49 AM
i fixed the previous problem with an article i found here on the website, i created the dll along with its library added them to bin/debug folder.
and now i have another error message saying the following:
Error interpreting the instrument's response
so what does that mean??? and what is the problem now ???
please help.
thanks.
01-04-2011 09:57 AM
Hi Ala Ayesh,
Can you take a screenshot of the error?
Thanks!
01-04-2011 10:04 AM
Hello Mr.Christopher,
i can send the screen shot tomorrow because am at home now but the error occurs due to the following line of code:
Dim myScope as new mxox802x ("GPIB::30",true,true)
some times it gives me "interpreting instrument response" error
or "Time out" error
sorry to bother you.
thanks
01-05-2011 03:24 AM
Dear Mr.Chirstopher,
here is the screen shot for the error that i have got.
thanks for your help.
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
