dll of the instrument driver can not be loaded
Do you mean that i had to create a win32 console application and add the .c and .h files and then run the project???
thanks
Message 11 of 24
(1,018 Views)
Hi Ala Ayesh,
The instrument driver is in C, you will need a C compiler to compile the mxox802x.c (not the mxox802xu).
Then have that DLL placed in the same folder.
Hope this helps!
Chris T.
Message 12 of 24
(1,002 Views)
Dear Mr.Christopher,
thanks am sorry to bother you a lot.
but can you give me a name of a c compiler to use, because i tried many ways to convert a .c file to a dll with no luck at all
i appreciate your help
thanks a lot.
Ala Ayesh
Message 13 of 24
(998 Views)
Hi Ala Ayesh,
I used LabWindows/CVI to compile the dll, make sure that you are only compiling the mxox802x.c and not the mxox802u.c (This references CVI specific functions).
Hopes this helps!
Chris T.
Message 14 of 24
(992 Views)
Hello again,
i still have the problem but now with an error message of
"can not find entry point "mxox802x_init" in mxox802x_32.dll"
i read that it is related to dllexport because it is a c dll and am trying to reference it in vb????????
did you get some thing like that?????
thanks.
Message 15 of 24
(950 Views)
sorry to bother you again
it seems we are going toward a solution but the problem now is that it says there are no entry point in the dll and i think it is related to the created dll using labwindows/cvi
because when i created the dll it says dll with no exports won't have imports and so i can't import the dll functions on my application.\
so do you know a solution for that ???
please help
looking forward to hearing from you soon.
thanks.
Message 16 of 24
(935 Views)
i fixed the previous problem with an article i found here on the website, i created the dll along with its library added them to bin/debug folder.
and now i have another error message saying the following:
Error interpreting the instrument's response
so what does that mean??? and what is the problem now ???
please help.
thanks.
Message 17 of 24
(932 Views)
Hi Ala Ayesh,
Can you take a screenshot of the error?
Thanks!
Chris T.
Message 18 of 24
(887 Views)
Hello Mr.Christopher,
i can send the screen shot tomorrow because am at home now but the error occurs due to the following line of code:
Dim myScope as new mxox802x ("GPIB::30",true,true)
some times it gives me "interpreting instrument response" error
or "Time out" error
sorry to bother you.
thanks
Message 19 of 24
(885 Views)
Dear Mr.Chirstopher,
here is the screen shot for the error that i have got.
thanks for your help.
Message 20 of 24
(866 Views)
