07-16-2018 09:13 AM
I am totally new in this platform and need help regarding continuous current/resistance measurement using Keithley 6487 picoammeter and a serial bus (rs-232 straight through cable).
The current/resistance measured shall be made at a user defined voltage.
It would be great if someone with the same issue has a help on offer.
Best Regards
07-16-2018 10:31 AM
What platform are you using? Have you tried looking for drivers for this device you can use?
07-17-2018 03:10 AM
Dear crossrulz,
Thank you for your interest to help. By platform, I meant labview 2018. I have driver for Keithley 684X series installed and I can see three examples but unfortunately it is not what i exactly need. I was able to connect my device (keithley 6847 picoammeter) with these examples but my requirement is just measurement of current at a selected voltage. Basically, I need to give a voltage to my device and measure current from it using RS-232 straight through cable.
Best Regards
07-17-2018 04:36 AM
In addition to issues stated in my previous reply, I need a continuous current measurement. My device has a range from -500 to + 500 V. I need to measure current continuously at specified voltage within this range and plot the current vs time with a stop push button to end the program. The duration of current could be few hours or even days. The measured data(CURRENT) is required for further analysis.
Best Regards
07-17-2018 06:44 AM
Break your problem down. First you need to figure out how to set the voltage. I imagine there is a simple VI in those drivers to do that. Then you need to figure out how to get your measurement. Again, there should be a simple VI for that. After that, put the steps in a loop and make it do what you want.
