02-24-2016 12:16 PM
Solved! Go to Solution.
03-03-2016 05:15 AM
The cRio was indeed bricked and safemode needed to be restored.
Instructions and files for recovery have been comunicated via technical suport.
Guy
07-13-2018 02:37 AM
Hi Everyone!
I also have a cRIO 9066 with firmware version 3.00.
In LabVIEW/MAX (18.0.0) I tried to configure the hardware. It is in safe mode, the yellow led blinks 2 times.
I can see it and configure the system and network related issues but at the software tab I see a message that firmware should be updated to at least 5.0.0.
I have found version 6.0.0. in patch NIRIO15.01, ut when I try to update it (from the file cRIO-9066_6.0.0.cfg), an error message comes:
"There was a problem updating the firmware for this device.
Error code: 800407E2"
I have no idea what can be the next step or what I have made wrong.
Thanks in advance for your help,
Attila
01-18-2022 09:07 PM
That would have been cool if the instructions for unbricking were *Here* instead of someone's mailbox.
