09-27-2013 05:57 AM
Hi guys,
I want to controll/interface Tektronix MSO 2014 mixed signal oscilloscope from LABVIEW so that i can execute command changes for various parametrs like duty cycle and current/voltage values, as its an optical system with use of lasers so its highly undesired to do it manually(by hand) again and again while disturbing the isolation for the wholse system.
kindly help.
Thanking you all in anticipation
Regards
Umar
09-27-2013 06:33 AM
09-27-2013 06:39 AM
thanks for the prompt reply, I actually want to get hold of the driver, which driver i need to use/install to get this done,
09-27-2013 06:48 AM
Try going here (Tektronix MSO2014) on the Instrument Driver Network (IDN).
09-27-2013 06:51 AM
