control 4 speeds by a Joystick
hello,
I wanna control the Date Control ( velocities in X, Y, and Z, and yaw ) in attached VI by using  a Joystick. And I enclosed the program in a while loop with a 1000 ms Wait to make it send every one second,but it does not work.
i need to know how to make those. And if you think my work is wrong, please tell me.
thanks.
Message 1 of 16
(4,380 Views)
It must be the command that you are sending, the rest looks ok.
greetings from the Netherlands
Message 2 of 16
(4,375 Views)
thanks.
please, Explain it in details, I am a beginner.
thanks.
Message 3 of 16
(4,371 Views)
Well, you have not provided the programming manual for the device you are connected to, not even the make and model. How can anyone tell whether the commands are correct? I don't understand your comment about a joystick. There is nothing in your code for reading one. For that you would use the functions on the Connectivity>Input Device Control palette.
Message 4 of 16
(4,367 Views)
okay.
for Joystick command
In the attached VI, there's a cluster called Data Control.
i wanna control them by a Joystick.
i didn't understand what are you meant by " There is nothing in your code for reading one"
thanks for your intersted in help.
Message 5 of 16
(4,358 Views)
If you give us the possibility to help, otherwise you have to find out what is wrong with the command yourself.
Message 6 of 16
(4,356 Views)
tell me more about what are you need in points to help me correctly ?
thanks
Message 7 of 16
(4,355 Views)
really I need the help.
thanks
Message 8 of 16
(4,354 Views)
Dennis told you, a manual and name of the system you want to control
Message 9 of 16
(4,352 Views)
And look at the LabVIEW example for reading a joystick.
Message 10 of 16
(4,351 Views)
