checking if a device gets disconnected
Assuming multiple devices were opened successfully using ibdev, what would be the best method to check if a device get disconnected or goes offline?   I was thinking of just having a timer that would call FindAllListeners and comparing it with the list of successfully opened devices.  Or would a serial poll be a better solution?  Each device would get serial polled say every second.
(3,349 Views)
Why are you so serious about someone switching off a device or disconnecting it?
Each second is very short, what are you expecting?
greetings from the Netherlands
(3,338 Views)
Hello sny:
Thank you for contacting National Instruments. Have you tried opening NI-SPY and then doing a scan for instruments in Measurement & Automation. NI-SPY will list all the commands being sent to check which devices are present, you can use those commands if you choose to.
Roland A.
Check out VI Roadshow
(3,318 Views)
