cRIO, PSUs, MFCs connected via Ethernet
I am trying to use Labview to control and save data from several power supply units (PSUs) and mass flow controllers (MFCs).
In particular, I am using a cRIO 9031, an Ethernet switch (TP-link), PSUs (Sorensen and Keysight) and MFCs (Bronkhorst).
I'd like to connect the cRIO to the Ethernet switch and then use the switch to connect the other hardware.
Can you please suggest me how to correctly configure the setup?
Message 1 of 1
(724 Views)
