cRIO-9025 USB port
Can I use the USB port on cRIO-9025 to read serial data from an arduino?
I have been able to serially read the data into LabVIEW using VISA, I would lke to read it into the cRIO, is it possible?
Soliciting a quick reply.
(2,305 Views)
I meant, can the Hi-Speed USB host port used for serial communication with an external device?
I have connected to the USB port on my PC and have used Ni-VISA. Can i use VISA on my cRIO-9025 to read data serially from the USB port?
(2,274 Views)
The data Sheet says RS 232 can be used serially. Can I use the USB port for serial communication?
Thank you very much!
(2,266 Views)
