10-06-2014 10:13 AM
so i got everything installed now except for the NI-DAQmx OPC Support 14.1.0 wich greats me with an error message i inclueded in this post. even though the software of the hardware shows me that i have the 14.1 installed the 4065s still tell me driver 9.7 is incompatible. so i guessed it ahs something to do with this last driver im unable to install. i include the error message and again the new reports
10-06-2014 10:22 AM
I think you need the LabVIEW Real-Time Module in order to get the needed dependencies.
If you have the LV RT Module installed on your Host PC you should be able to install everything you need.
regards
swirl
10-07-2014 03:04 AM
is that included in the base licence or do i need to place another purchase?
10-07-2014 03:19 AM
The LabVIEW Real-Time Module isn't included in the Base License.
It is necessary to properly use your Real-Time Device and to install all needed Software for your System.
You have the option to try the RT Module for 45 days.
Download LabVIEW Real Time Module:
http://www.ni.com/gate/gb/GB_EVALTLKTEMBDES/US
swirl
10-08-2014 04:37 AM
ok so i finally got everything installed but now im clueless on how to get readouts into labview vi's. the NI-DMM/Switch Express function is showing <no device found> even though ni max is running and showing that all hardware is ready and recognized correctly.
10-10-2014 09:16 AM
the Express VI isn't supported in LabVIEW Real-Time.
In the following KB it is explained how to deal with this issue:
http://digital.ni.com/public.nsf/allkb/23D6B06A78D797C7862570D2005D170A?OpenDocument
swirl
