after creating the exe file, VISA gives an error
A simple Visa data exchange program stops working after an exe file is created, while GPIB exchange is possible, and through TCPIP it gives error -1073807298. In Vi both protocols work. What could be the problem?
Labview 2016, NI-Visa 16.0
(2,858 Views)
Have you checked out the troubleshooting steps in this article?  Also, are you using NI hardware or a 3rd party device?
DillonL.
(2,818 Views)
Is the exe running on the same computer ? If not probably VISA runtime is not installed. Maybe something wrong with the IP addresses.
If yes, did you select the correct IP address ?
Kees
(2,806 Views)
