Online shopping is currently unavailable.
Please contact us for help or try again later.
Yellow Light on GPIB-USB-HS
Yes.
Message 11 of 15
(3,013 Views)
On the image you posted, all of the settings are grayed out and there's a message about properties only being changed by an administrator.
That could be the source of your problem. Try reinstalling 488.2
You should be able to change the settings. See my image.
Curt
Message 12 of 15
(3,007 Views)
@PLL_Geek wrote:
I just installed my new USB interface. It appears in the devices and interfaces, but when I run scan for instruments, it just blinks (doesn't say no instruments found). Allow the ready light on the interface is yellow. I am trying this with a HP4418 power meter and I search the forum for some information. It said something about modifying the VISA passports, but the link to the information was broken.
PLL_Geek, were you ever able to resolve this issue?
First off, it is perfectly normal for the Ready LED on your device to be yellow. Yellow indicates that it is connected to a USB 2.0 port, and green indicates that it is connected to a USB 1.1 port.
As for it not seeing your instrument, if you are still having the issue could you perform a capture using NI I/O Trace and attach it to a reply? The following KB describes this process:
Performing a Good NI I/O Trace Capture for Debugging/Troubleshooting
-Jason Smith
Message 13 of 15
(2,971 Views)
Hello Everyone,
Yes, I finally got it to work. It was very stupid. I went to a friends house and tried the same thing with his NI USB interface. Same problem. Used another brand interface and it worked. After a while and a lot of head scratching, we tried a GPIB calbe from the dongle to the instrument and it worked fine !!. I assume plugging the dongle directly into the instrument did not result in a good connection. Thanks again.
PLL_Geek
Message 14 of 15
(2,969 Views)
@PLL_Geek wrote:
Hello Everyone,
PLL_Geek
Usually instruments should work with the GPIB-USB-HS plugged in directly. It may have been a connection issue, but increasing the GPIB cable length also has the effect of slowing down the GPIB handshake. We occasionally see older instruments that make some incorrect assumptions about timing when handshaking, where increasing cable length could make a difference. I would expect an HP instrument to handshake correctly, but it may be worth seeing if there is a firmware update for the instrument, just in case.
Message 15 of 15
(2,961 Views)
