Situation: We are using a GPIB-120B extender to drive up to ~20 Tektronix digitizers on a GPIB bus. With all 20 instruments on it works fine.
Problem: When using the system with just a few digitizers on (the rest off but still physically connected as part of the GPIB daisy-chains) MAX could not detect the digitizers that were on. Consequently the controlling software (Labview) failed.
In the GPIB-120B manual it states "Where there is GPIB activity, it is recommended that you keep at least two-thirds of the devices on both buses powered on." Unfortunately, the manual gives no explanation of this. Doing a Google search shows that there are similar statements for most National Instrument 488.2 devices.
Solution: Turning on most of the instruments on both sides of the extender solves the problem - but we do not want to do this.
Questions: Why must 2/3rds of the instruments be on for the bus to work? We would like to find a workaround for this but do not want to physically change the GPIB daisy-chain to suit the number of powered on instruments. A simple fix that is independent of the number of powered on instruments is required.
Thank you
