Hi Petey,
This often happens if you install the card in the computer before you install the drivers. Before even plugging in the GPIB Device into the USB port, have the 488.2 drivers installed. The 488.2 driver version 2.4, the most recent driver, can be used with the GPIB USB High Speed devices. If the drivers are already installed, you may be able to go into the device manager, find the "unknown device" and right click and select "Update Driver". This sometimes will reassociate the driver files with the device and your device will work. Your device should be located in a section called "National Instruments GPIB Interfaces" within the device manager. If this doesn't work, remove the device from the machine, uninstall the NI-488.2 drivers, reinstall the drivers, reboot the computer, and then plug in the GPIB device. Windows should go through the installation of the new hardware and automatically find and associate the drivers. Good luck! Let me know if you have any trouble!
Chris R.
Chris R.
