11-20-2010 04:29 AM
We are using GPIB-PCI card and it came with the ancient CD "NI GPIB 488" driver version 1.7. The measurement and automation version is 1.7. We specifically use the "gpib-32.dll" to do your basic ibwrt, ibonl, GPIB communication in Visual Basic 6.
Once I immediately upgraded to NI VISA 488 version 2.5 CD, our program crashes saying that a problem occured with gpib-32.dll ?? When we reverted back to version 1.7, all was okay in Visual Basic 6. The new CD version 2.5 also came along with our hardware GPIB-PCI card.
So can someone tell us why the software is crashing with gpib-32.dll ? When we tried to replace teh gpib-32.dll from version 1.7, this also did not solve the problem.
11-20-2010 10:09 AM
NI-VISA has nothing to do with this. There is no version 2.5 of NI-VISA. It is NI-488.2 that you are trying to install and the latest version is 2.7.3. Version 2.5 has not been "new" for a while.
I would suggest a complete uninstall of the old version first instead of trying an update. Then, test communication with the instruments in MAX.
11-29-2010 09:42 AM
If you are making direct calls into the gpib-32.dll, the functions in the dll may have changed from 1.7 to version 2.5. I would recommend stepping through your program...finding the exact NI-488.2 calls that are causing the problem and then you should see if the function was depricated or changed.
Also, since you are upgrading your driver, you should re-compile your program with the new driver.
Steven T.
