What switches and/or files do I need to include or link on my cc compile command from a HP-UX 10.2 command prompt using NI-VISA functions and the visa.h header file
The error it gives me is that the pointer is not assignment compatible..and Assignment #2 was not valid .I was using the example 2-1 from the NI-VISA User Manual. I was using the following compile command
cc -Ae -I/usr/include -lvisa -c filename.c.
The compile error goes away once I take the viWrite function out. What am I doing wrong..
(3,050 Views)
You can find multiple examples in (assuming a default installation) "/opt/vxipnp/hpux/NIvisa/Examples". We recommend gcc but you should be able to use cc if you want. The examples use a Makefile with directions for each.
Dan Mondrik
Senior Software Engineer, VISA
(3,050 Views)
