What driver do I use for a PCIX GPIB with NI NAT9914 chip for use with a Waters 515 PCM?
I'm looking for the correct Windows XP driver to use with a PCIX GPIB with NI NAT9914 chip that will control a Waters 2487 UV detector and two Waters 515 HPLC pumps connected via a Waters Pump Control Module. A picture of the card is attached. Thank you very much in advance.
Message Edited by dimeless on 03-18-2008 10:24 AM
(3,656 Views)
Hey Dimeless,
While the chip NAT9914 is National Instruments and can communicate via GPIB, the company who created the board should have created a driver for it. That chip is customized for their device and so NI has no idea what it can/can't do. You may want to contact the waters company if a driver is needed.
Hope it helps
Can W.
Can Wong
(3,610 Views)
