09-05-2018 01:12 PM
Hi!
Yes. I did the configuration recommended, however, there is a slower communication than last configuration.
I need to have a fast serial communication continuously! How to achievement a fast serial communicaction e.g (50ms per iteration from reading mode)
I attached a few pictures
09-05-2018 01:31 PM
1. You can remove the wait in that loop.
2. You should remove the Serial Monitor and the related Concatenate String and shift register. When you constantly add to a string, this becomes a slow memory allocation over time.
3. I would replace your XY Graph with a simple Chart. This way you don't have the ever-growing array issue, which can really slow down your loop. And the Chart also keeps a history (defaults to 1024 samples). So this would also remove the need for the Build Arrays and shift registers.
4. There is a primitive called Increment that does the +1. This will save you some space and make things more readable.
5. There is a primitive called Empty String/Path? that you should also look at using instead of comparing a string to an empty string.
09-05-2018 02:26 PM
1.- I use the wait to wait for Arduino to exit boot loader.
2.- I have a GUI, where It's necessary to have the serial monitor for the history of the user commands.
3. I will replace the XY Graph with a simple Chart.
4. the primitive called Increment helps me to create a Index of the History into .txt file.
To be honest, I have used the last configuration and runs better than this but, my last configuration some times breaks the serial communication. So, I sent the topic : Visa Serial Communication via Serial port COM# is unreliable.
I attached a pic of the front panel.
Thank you!
