Visa Error -1073807246
Hello all ,
I am realizing a  simple VI that receives the state of 4 sensors through serial connection , and then displays them as LED outputs .
The problem is that am getting a  " VISA error (Hex 0xBFFF0072) -1073807246 : The ressource is valid but visa cannot currently access it " .
Is it a  VISA driver problem ,  a subVI configuration error or a number of bits compatibility ?
I'm attaching the VI and a screenshot of the bits received on my HyperTerminal .
Any help is much appreciated .
Best regards .
(2,204 Views)
Accepted by topic author Houssem95
A serial port can only be accessed by one application.  This means you cannot have Hyper Terminal open at the same time as your application.
GCentral
(2,189 Views)
