VISA serial configuration
Today I made a little program with VISA serial.
The device connecting to PC has a "COM4"  displayed in Windows device manager.
Right click on the "COM4" icon I can setup the Baudrate etc (9600 bit/sec; Databit 8 ; no parity; stopbit 1)
In the labview program, I made a different setup (9600bit/sec; Databit 7; Even parity; stopbit 2)
The data can still be correctly receivd.  Why is it lik that?
Can anybody give a little explanation on it?  Thanks in advance.
Message 1 of 12
(6,543 Views)
You have to match the settings of the instrument. What is or is not displayed in device manager has nothing to do with what is supposed to be set for a program to communicate to the instrument. Windows device manager does not do any communication to what the com port is connected to.
Message 2 of 12
(6,542 Views)
Thank you very much for the information.
May I have one more question?
Q: In the labview program I have already tried two setups: A. No parity, 8 databits, 2 stopbits      B. Even parity, 7 databits, 1 stopbit
The program worked both fine with two different setup.
How is that possible? (I asked because I also believe the program setup should be matching the device setup)
Message 3 of 12
(6,527 Views)
Accepted by SergioMa
I don't know why it works. It shouldn't. What's the device?
Message 4 of 12
(6,463 Views)
if the device is sending data slowly it may match when even parity is correct then no parity does not perform the check. When the device has more then one bitperiod between two characters then two stopbits are ok just as one stopbit.
Message 5 of 12
(6,411 Views)
Is YOUR device a true RS232 device?
Or is it a USB device with a provided driver that "appears" as a virtual COM port?
Do you have a single USB cable that goes from a USB connector on your computer to a USB connector on your device?
Just because your device driver creates a virtual COM port does not mean it is RS232.
If it is a purely USB device and is never converted to RS232 (like a lot of small cpu boards are) then the Baud Rate, Data Bits, Parity and Stop Bits have no effect. They have no function. The connection is defined by the USB protocol and the are no settings that you can change.
I have a similar device and the user manual clearly states that the Baud Rate does not matter. But the Flow Control Does. Set to NONE.
What does the user manual of your device say?
Omar
Message 6 of 12
(6,342 Views)
I do thank you all for the assistances. Truely from my heart.
As you said, the device is just a "virtual com" displayed on windows "device manager". I don't know which protocol the device uses exactly for communication.
Can you anyhow give me some explanation why the data frame setup (stopbit number etc,) doesn't interfere the data exchange with the device of "virtual com" port?
Message 7 of 12
(6,315 Views)
Your virtual com port needs to be connected to some sort of instrument. What is it?
Message 8 of 12
(6,290 Views)
That is a question you need to ask the "device connecting to PC" manufacturer. I assume you had to install some type of device driver.
Protocol? Well its not RS232. It is what ever your device manufacturer decided to use in the device driver. It could be anything. We really do not care, as long as the device software driver works.
I am sure that the device software driver does not use the baud rate, data bit or stop bit. It ignores them.
Again, this is a question to ask the "device connecting to PC" manufacturer.
Omar
Message 9 of 12
(6,275 Views)
It is a Lora device
Message 10 of 12
(6,248 Views)
