12-27-2011 04:26 PM
I am communicating with a TCP/IP device using VISA functions.
If I wait more than aprox. 50 seconds to talk with it, occurs the following errors:
When the VISA timeout is set to 10 sec:
Error -1073807298 occurred at VISA Read.
VISA: (Hex 0xBFFF003E) Could not perform operation because of I/O error.
When the VISA timeout is set to 20 sec:
Error -1073807194 occurred at VISA Read
VISA: (Hex 0xBFFF00A6) The connection for the given session has been lost.
When the VISA timeout is set to 20 sec and TCP KeepAlive property is enabled occurs the first error again:
Somebody can knows how to solve it?
12-28-2011 05:54 AM
12-28-2011 07:39 AM
It is a Telecom product, the manager of a DWDM (optical) system.
12-28-2011 07:43 AM
A workarround is open (write, read) and close the TCP/IP VISA session each time I communicate with it.
What do you think about it?
I usually open and close the device session only one time in my applications, at least GPIB and serial communication...
12-28-2011 12:10 PM
I think somethings odd. Show us some code that demonstrates the behavior and we'll see what's wrong
12-29-2011 04:30 AM
I've discovered the supplier's sw to control this equipment sends packets to it to keep the connection opened. There is no KeepAlive function for it. It has to receive valid packets, a "GetStatus" command for example. If no command is sent, after ~50s, the connection is closed.
12-29-2011 09:04 AM
If the device is commercially available- could you post a model number and a link to the relavent documentation? The next forum member that runs accross this issue won't have to share your pain and can resolve a problem with a quick search. Thanks
