VISA: (Hex 0xBFFF0015) Timeout expired before operation completed.
I am using an Agilent 6675A DC power supply and want to control this through LabVIEW. I have a GPIB to USB converter and have connected the supply to the computer through this cable. On opening up NI MAX, I see COM3 as the USB port which is connected. On running the VISA Test Panel with the *IDN?\n command and clicking query, I get the error ' (Hex 0xBFFF0015) Timeout expired before operation completed.' I have increased the timeout, however I still get the same error. I observe in the 'View Attributes' section, I have an 'Invalid Property Value' for the 'Is Port Connected' attribute. However, on reading few other posts, I understand this can be ignored if the GPIB to USB cable is a non-NI cable as is my case. Since the COM3 port shows up in NI-MAX, could the non-NI cable still be the reason for this error? If not, could someone help me troubleshoot this error?
(4,726 Views)
I currently have an Agilent Power Supply I want to control through LabVIEW. The power supply has a GPIB port and I have a GPIB to USB converter to hook this up to my computer's USB port. I have installed the instrument driver and NI VISA. Do I also need to download NI 488.2 to use the instrument through LabVIEW? I am currently getting a 'Timeout expired before operation completed error'.
(4,712 Views)
Hi
Do not spam the forum with the same question and a different header.
Please tell which gpib interface you have and why you don't ask the vendor?
greetings from the Netherlands
(4,714 Views)
Could you elaborate on what you mean by 'which GPIB interface' I have? I have a standard Prologix GPIB to USB controller
(4,709 Views)
Hi
Have a look at the following thread
https://forums.ni.com/t5/Example-Program-Drafts/Prologix-GPIB-USB-Controller/ta-p/3539152
This library should help you.
(4,703 Views)
