02-29-2012 09:41 AM
Windows 7 Professional 64-bit
Labview 2010SP1
NI-VISA 5.0
Greetings,
I've written some Labview code to interface with an instrument using USB RAW communications. There is no Labview driver for this instrument. Things work ok for the most part, but periodically I get error 0xBFFF003E (Could not perform operation because of I/O error.) when I do a VISA Read. I've searched through the discussion boards and most references to this error seem to relate to RS-232 communications problems. I haven't seen much discussed regarding USB comms.
When this error occurs, I will continue to receive the error on every subsequent VISA Read. The only cure I've found is to call VISA Clear after this error is detected. This seems to work ok but is a pretty ugly solution, and it also causes a little bit of a delay in the code during which the user can no longer interact with the device.
In a nutshell, my Labview code has two loops. One loop is a queued message handler that handles user interaction, and when nothing else is going on it sends some status requests to the instrument once/second. The 2nd loop calls VISA Read continually with a 50ms timeout. Most iterations this will generate a timeout error since there's nothing to read. Once per second it will return the status data requested from the instrument. Then, once in a while I get the I/O error. Here is a brief capture from I/O Trace that shows a little bit of the normal functionality and the error at the end (event 112). Thanks for any suggestions.
Dave
95. VISA Write ("pico3", "TER2?.")
Process ID: 0x00000828 Thread ID: 0x000040F8
Start Time: 07:26:18.782 Call Duration 00:00:00.000
Status: 0 (VI_SUCCESS)
96. VISA Read ("pico3", 512, "TER 2,00000..", 13)
Start Time: 07:26:18.783 Call Duration 00:00:00.003
> 97. VISA Read ("pico3", 512, 0)
> Start Time: 07:26:18.787 Call Duration 00:00:00.101
> Status: 0xBFFF0015 (VI_ERROR_TMO)
> 98. VISA Read ("pico3", 512, 0)
> Start Time: 07:26:18.888 Call Duration 00:00:00.102
> 99. VISA Read ("pico3", 512, 0)
> Start Time: 07:26:18.990 Call Duration 00:00:00.101
> 100. VISA Read ("pico3", 512, 0)
> Start Time: 07:26:19.092 Call Duration 00:00:00.101
> 101. VISA Read ("pico3", 512, 0)
> Start Time: 07:26:19.193 Call Duration 00:00:00.102
> 102. VISA Read ("pico3", 512, 0)
> Start Time: 07:26:19.296 Call Duration 00:00:00.102
> 103. VISA Read ("pico3", 512, 0)
> Start Time: 07:26:19.398 Call Duration 00:00:00.101
> 104. VISA Read ("pico3", 512, 0)
> Start Time: 07:26:19.499 Call Duration 00:00:00.102
> 105. VISA Read ("pico3", 512, 0)
> Start Time: 07:26:19.602 Call Duration 00:00:00.102
> 106. VISA Read ("pico3", 512, 0)
> Start Time: 07:26:19.704 Call Duration 00:00:00.101
> 107. VISA Read ("pico3", 512, 0)
> Process ID: 0x00000828 Thread ID: 0x000038D8
> Start Time: 07:26:19.805 Call Duration 00:00:00.101
108. VISA Write ("pico3", "TMP?.")
Start Time: 07:26:19.907 Call Duration 00:00:00.000
109. VISA Read ("pico3", 512, "TMP +028..", 10)
Start Time: 07:26:19.907 Call Duration 00:00:00.004
> 110. VISA Read ("pico3", 512, 0)
> Start Time: 07:26:19.912 Call Duration 00:00:00.101
> 111. VISA Read ("pico3", 512, 0)
> Start Time: 07:26:20.013 Call Duration 00:00:00.101
> 112. VISA Read ("pico3", 512, 0)
> Start Time: 07:26:20.115 Call Duration 00:00:00.001
> Status: 0xBFFF003E (VI_ERROR_IO)
113. VISA Clear ("pico3")
Start Time: 07:26:20.116 Call Duration 00:00:00.001
> 114. VISA Read ("pico3", 512, 0)
> Start Time: 07:26:21.120 Call Duration 00:00:00.101
03-01-2012 10:40 AM
Hello Jabson,
Could you post your code or a screenshot of it?
03-05-2012 08:57 AM
Also check the power comsumption of your device and the power stability of your USB hub (if using one).
Even some motherboard USB ports have dodgy power supply and I've come accross this problem in the past due to power cycling of devices under use....
Hope it helps
Shane
05-26-2012 02:37 AM
sir ,
I get the error(timeout expired error before operation complete or system time limit) in the visa read using usb raw resources.i m configure my instrument(usb mass storage device) in the visa interactive control .how can i overcome it and how to move(or read) the text document into(or from) the usb device.please give the kind response as soon as possible .i m waiting for ur favourable reply........
05-26-2012 07:45 AM
05-29-2012 02:13 AM
This
Why don't you simply use it as a normal drive within the OS, wouldn't that me MUCH easier?
