04-02-2019 06:35 AM
Whenever device driver tries to execute "VISA Enable Event" function with event type "Service Request" It gives an error "Error -1073807339 occurred at VISA Enable Event in Agilent 3352X Series.lvlib"
I am successfully executing *IDN?\n command and reset command using VISA.
10-09-2020 03:16 AM
Hi sumit04,
I have exactly the same Problem. Have you already found a solution for it?
Regards
10-10-2020 02:05 AM
HI,
I didn't get any solution for the same problem, but I have a work-around to avoid that problem.
The Reset.vi causing an issue so disabled it for now
10-13-2020 04:38 AM
finally I solved the problem for me. I had to adjust the Windows firewall settings. The Enable Event Message uses additional resources than the other messages.
Regards
10-13-2020 04:51 AM
Can you post some screenshot what exactly you changed in Firewall
10-13-2020 05:09 AM
There's a NI-page for this topic: https://www.ni.com/de-de/support/documentation/supplemental/10/configuring-software-and-hardware-fir...
I think for our problem it's important to allow access for the NIvisaic
In fact I opened the firewall for all NI applications and for those needed for VISA (searched for VISA in the firewall settings).
So I can't say which setting it was exactly that leaded to success.
05-20-2022 12:29 AM
In my driver package there is an "Initialize_LAN.vi" and a "Reset_LAN.vi".
There is a bug in the "Initialize_LAN.vi", the "Reset.vi" in the Reset (Enable) case has to be replaced by the "Reset_LAN.vi".
Apparently the problem was already recognized by the creator of the driver, but these vi's are not displayed in the function palette.
