VI_ERROR_RSRC_BUSY
I have LabView 6.0, Run-Time Engine 6.0.1, VISA Interactive control 2.6 and VISA Run-Time 2.6.0 and I need to control a HP34401A via seria port. When I run the VI it works properly, but when I built the application, it gives the message error VI_ERROR_RSRC_BUSY. I've tried to build a very small code just to initialize a visa section and I didn't have success. I was wondering if someone could help me.
(4,405 Views)
In the NI-VISA 3.0 (the next version to 2.6.x) README text, I found the following description:
For a Serial INSTR resource, viOpen will now open a port if the process
that had been using that port exited ungracefully (such as with Ctrl-C).
The previous behavior had been that viOpen would return VI_ERROR_RSRC_BUSY.
Although I don't know if this is concerning to your problem, try to check the following:
1) Check if your app does call viClose (VISA Close) function before exiting the app.
2) Try to upgrade NI-VISA 3.x or later.
Makoto
(4,393 Views)
