10-27-2020 05:25 AM
I hope I choose the right board for my problem.
I try to read out the pressure of a vacuum which will messure by a Granville-Philips 350 Gauge Controller. As an Adapter (serial to ethernet) I should use the Lantronix UDS2100.
For the first step, there should be a direct connection between this adapter and a laptop to read out the pressure data.
I don't have a lot experience with Labview and know I have a few problems I can't solve.
(1) I installed the DeviceInstaller for the UDS. The software show the device. When I choose the device there's an Error:
"Communications error. The configuration was not received from the device.".
After this the Device Info shows an Error too (see screenshort).
I tried to upgrade the Firmeware, but it doesn't work.
(2) The UDS is not show in de DeviceManager of Windows.
(3) I tried to add the device into MAX as a VISA TCP/IP. The device won't found. When I use the ip-adress it doesn't work too. (see NIMAX screenshort).
Maybe my problemes are more based on the UDS2100 than on NI, but I hope there is someone that can help me.
10-28-2020 05:07 PM
Please read the forum on
It is about the connecting wire that was wrong. Sometimes you need to solder, sometimes you need software only.
01-22-2021 10:39 AM
Did you fix the Problem?
I also need to connect the Granville-Phillips 350 Gauge Controller with the Pc using the UDS2100.
I looked at the other thread, but in my case the controller is directly connected to teh UDS2100 via a 9 pin cable, so there is no adapter between the Ion Gauge and the UDS which would change the signal.
