09-05-2008 07:22 AM
09-08-2008 10:00 AM
Did you try to communicate with the instrument through VISA Interactive? If you try running the examples do you see an error?
09-08-2008 11:34 AM
To ensure reliable operation of the communications link, (without data corruption due to noise or line reflections) the connections between the controller should be made using a twisted pair of wires inside a screened cable with the connections terminated with resistors. Also, the use of a Eurotherm KD485 converter to connect the EIA-485 link into a standard EIA-232 computer port might help simplify your wiring.
