08-20-2021 01:56 PM
Hi Community Friends
I have a Rhode and Schwarz DSA (fairly new instrument for measuring BER and MER and Spectrum analyzer functions). I wrote a very simple VI in Labview 2010 to just write commands to it. It has an Ethernet port. I tried using Visa and also TCPIP canned Labview VIs, enclosed. It doesn't work. It times out on the Read command even with the *IDN? query, giving the error 56 of timeout for TCPIP and an error -1073807339 which is also a timeout for VISA. I looked at the forums and there are some solutions there but they don't appear to apply here. I am at a total loss. R&S is no help, they have not even released drivers for this instrument yet.
I am talking to the sockets they recommend, 5900 or 5025, and neither of them work. Nor does the IP address alone work either. The byte count is always 0 and the error message the same. If I use NI Max, it doesn't work either. Any help would be much appreciated.
Thanks and regards
Locktofer
08-20-2021 02:00 PM
Thanks and regards
Locktofer
08-20-2021 09:22 PM
1. Make sure you are writing to the correct IP address. You will want to go through the settings in the DSA to make sure. It is possible it is set to use DHCP to set the IP Address instead of using a static address.
2. Make sure you are using a network port that can talk to that IP address. This would likely making your port have a static address that nearly matches the DSA's address (typically just a different last number).
