Using GPIB-USB-HS connect power supply PST-3202 can't respond *IDN?
Hello All,
I have the same issue as described by this thread starter.   The NI-488.2 for Windows Version 2.4  and GPIB-USB-HS present a  timeout error when trying to communicate with PST-3202 power supply.  Also I tried to use the GPIB-USB-B with the Version 2.4 software and get the same timeout error result but if I cycle the power supply, it will work fine.  The NI-Spy result is below.  The NI-488.2 for Windows Version 2.1 and the GPIB-USB-B communicate flawlessly with the PST-3202 power supply and other instruments.
Message 11 of 18
(3,250 Views)
Hi newey,
The fact that you are having the exact same problem with this instrument only reaffirms my suspicion that this is a firmware issue with the PST-3202.  Are you using any other devices with the GPIB-USB-HS?  Please let me know if you can confirm that your GPIB-USB-HS works with other instruments.  You might also contact Instek to report this problem.
Message 12 of 18
(3,239 Views)
Hello Michael,
The GPIB-USB-HS does work with other instuments but if I parallel them with Instek PST-3202 power supply, it will give me a time out error and will not communicate with any instruments.
Thanks for responding.
Message 13 of 18
(3,231 Views)
Hi Newey,
That's the exact same problem the other posters have seen.  I would definitely contact Instek support about this.  I've made our R&D department aware of this and they're investigating this, but the early concensus is that this is a firmware issue with the instrument.  Again, the -HS does have slightly tighter timing than the -B did, but it is still well within 488.2 spec.  This is the only instrument I'm aware of that had no problems with the -B, but does with the -HS.
Message 14 of 18
(3,205 Views)
Hi all,
Just got the same kind of problem with pst & USB-GPIB-HS.
Seems the PST cannot always respond the same format sting.
Asking for example Voltage or Current measurment , the PST
sometimes keeps part of the data, then release it at the next
reading that means.
No way out except retrying, sorting , filtering the data, then
select and return the correct ones... that's problematic a lot.
I report to instek support last week...
No answer at all.
David
Message 15 of 18
(3,056 Views)
Update:
My issue has been solved.   Instek Service and Quality Manager has sent me the EPROM replacement chips which fixed the firmware issue of PST-3202 for GPIB-USB-HS.  The replacement was a breeze.  All you have to do is take the casing off and the EPROM is located on the back of the case on the GPIB card.  Hope this help.Smiley Wink
Message 16 of 18
(3,051 Views)
Waahhh
Hope I'll get the same... that's chip tuning...
Thanks for your replay.
Dave
Message 17 of 18
(3,047 Views)
I'm glad to hear that Instek has found a solution to the problem, and thanks newey for sharing your results 🙂
Message 18 of 18
(3,025 Views)
