Using CVI driver for 16542a DAQ card of LA(16500c), when imported into Labview7.0 and the 16542a_32.dll called, flashes an error " The procedure entry point GetTreeItemLevel could not be located in the dynamic link library cvirte.dll."
I followed the step you followed above for converting the CVI driver to LabVIEW VIs and I was able to convert them to LabVIEW VIs ok. Here is the LLB it created. I'm not sure how to see the error you are seeing. Could you explain how from the attached LLB below that I can see the flashing error you are referring to?
Steven B.
Applications Engineering
(3,393 Views)
Thanks for the response. I's able to resolve the issue. It was a CVI runtime engine version issue. On downloading the correct runtime engine CVITRE7.0, the error got removed and the VIs got correctly converted to Labview.
(3,393 Views)
Great! I'm glad you got that to work. Good luck with your application!
Steven B.
(3,393 Views)
