02-07-2013 03:24 AM
How can i Uninstall the NI 488.2....?, i did not find it on removing/unistall program in WIN7.
Solved! Go to Solution.
02-07-2013 03:30 AM
When i try to remove it using the NI LabVIEW device Driver DVD August 2011, the error i found is attached.
it says i t can not be removed, repired... why,, is there any other software should be removed first inorder to remove it or anything tricky procedure there to remove ?
02-07-2013 03:38 AM
when i remove the NI VISA using Device Driver DVD... here is the ?
02-07-2013 03:45 AM
Sorry.... the Previous one is not true.... ther is no change in NI 488 after unintalling NI VISA ...
02-07-2013 04:17 AM
ITS TOO EASY................. JUST GO TO CONTROL PANEL/ UNINSTALL A PROGRAM/ NATIONAL INSTRUMENTS PROGRAMMS/ DOUBLE CLICK AND CHOOSE NI 488 FOR REMOVE....... RESTART AND COMPETE THE UNSTALLATION............. TOO EASY
THANK YOU
