05-21-2009 04:18 PM
I am trying to program a NI GPIB-USB-B to look like an instrument. Using property nodes, I am able to read the configuration but not change the configuration. I am suspecting that NI-MAX may be running in the background and causing the problem as the read configuration always follows the NI-MAX settings.
Any Ideas??
05-26-2009 06:54 AM
Gary Y,
You are correct, many of the options for your GPIB-USB-B will need to be done in MAX, can I ask what specifically you are trying to change?
Eric K
Applications Engineering
02-08-2011 02:59 AM
I am not able to configure the GPIB USB for my machine.
I have added the new interface in the gpib.conf
interface{
minor = 0
board_type = "ni_usb_gpib"
name = "usb_connector"
master = no
pad = 0
sad = 0
timeout = T3s
But Running the gpib_config utility give the follwing error :
failed to configure boardtype: ni_usb_gpib
main: Invalid argument
if i try loading firmware manually
fxload -D /proc/bus/usb/002/004 -I niusbb_firmware.hex -s niusbb_loader.hex
gives following error
write external: Connection timed out
unable to download niusbb_firmware.hex
I have installed the hotplug and fxload.
Any help in this regard is greatly appriciated.
HG
02-09-2011 09:43 AM
himanshu7gupta,
Have you been able to configure your device in MAX? Which device do you have? What operating system are you using?
02-25-2011 05:19 AM
Hi D beil ,
I am able to configure the USB.
I am having GPIB-USB-HS( Nationa Instrumnets).
I am facing one issue i am not able to make the device as non controller.
For controller i am using the ibtest program given in the linux-gpib-3.2.14 examples. from ibtest i am opening the board and sending the command 33 for making other gpib device as listner. Now i am making the board terminal as talker device and sending the data.
Data sent is recived at the Non controller end now i am calling the ibwrt API for writing the response. For this again i am sending the command 65 for making the non controller as Talker now. But it is not getting change to talker the ibsta shows still the listner bit is set.
The behaviur is inconsitence one in ten time i am able to make the device as listner and able to read the data through ibtest program.
I am working on non controller part only. Any help in this will be helpful
for non controller i am using the following program:
#include "gpib/ib.h"
#include <stdio.h>
#include <iostream>
#include <stdlib.h>
#include <unistd.h>
using namespace std;
static char buffer[100];
static int panelHandle;
static int noncontroller;
int main ()
printf("entered main ");
cout <<"entered main "<<endl;
int err;
// Open a session to the GPIB board
// err = noncontroller = ibfind ("violet");
err = noncontroller = ibfind ("usb_connector");
//noncontroller = ibfind ("gpib0");
cout <<"ibfind done "<<endl;
cout << err << endl;
// Release system control
err = ibrsc (noncontroller, 0);
cout <<"released "<<endl;
// Change primary address from 0 to 1
err = ibpad (noncontroller, 1);
cout << "LACS="<<(err&LACS) << endl;
// uint8_t ret = MLA (1);
// cout << "MLA ="<<(int)ret << endl;
while (1)
//cout <<"before ibwait "<<endl;
// Update Status variable
err = ibwait (noncontroller, 0);
cout <<"after ibwait status =" <<err<<endl;
//cout <<"after ibwait "<<endl;
// Wait until non-controller is listener and ATN line is dropped.
if ((ibsta&LACS)&&(!(ibsta&ATN)))
cout <<"reading "<<endl;
cout<<"LACS is set"<<endl;
ibrd (noncontroller, buffer, 100); // Read data bytes
printf ("%s\n",buffer); //print buffer
buffer[ibcnt] = '\n'; // Add linefeed and 0 to string.
buffer[ibcnt + 1] = 0;
printf ("%s",buffer); //print buffer
//return 0;
//Send (noncontroller, 0, "Iamat alker", 13, 0);
// If addressed to talk, send the response "I am a talker"
if ((ibsta&TACS)&&(!(ibsta&ATN)))
// cout <<"writing "<<endl;
cout<<"TACS is set"<<endl;
// ibrsv(noncontroller, 64);
// Send data across the bus.
//ibwrt (noncontroller, "I am a talker", strlen("I am a talker"));
ibwrt (noncontroller, "I am a talker", 13);
//send (noncontroller, 0, "I am a talker", 13, 0);
//return 0;
} // second if
} // while
return 0;
} // main
02-28-2011 01:13 AM
Hi ,
I am getting this error while calling the ibwrt API:
RCI: ibutil.c:384: conf_lock_board: Assertion `conf->has_lock == 0' failed.
can any one tell how to resolve this.
02-28-2011 08:38 AM
That assert message is not of the form that our NI-488.2 driver asserts take. From the message, I don't think that you are using the NI-488.2 driver to communicate with your NI GPIB USB interface.
Who-ever made your driver will be able to support this issue.
Steven T.
02-28-2011 04:16 PM
himanshu,
I do not see command 65 being sent. Where in the code do you write that?
Also, what driver are you using? Is this the NI-488.2 driver? Or a third party driver?
03-10-2011 07:57 AM
I am getting error for calling ibclr(Devicedescriptor);
The error is EARG.
for otherAPI(ibrd,ibwrt) it is woking fine.
I am using NI drivers and GPIB-USB-HS on Linux system.
Any suggestion?
03-10-2011 08:01 AM
Do we have to call ibonl() for every unsuccessful GPIB call (ibwrt , ibrd , ibclr ,ibpad) or when we are done with the device.
