12-02-2014 11:36 AM
I am running an iMac with OS X 10.5.8, a 2 GHz Intel Core 2 Duo processor, and LabVIEW 7.1. LabVIEW said it installed correctly, and I have even gone back and reinstalled the GPIB software on its own. I've tried reinstalling the entire software package several times. When I try to run the NI-488.2 softwares, the following things happen:
EthernetConfig: Starts to open, and then just closes itself
Explore GPIB: Unable to load libgpibconf.jnilib. Reinstall the NI-488.2 driver software.
FirmwareUpdate: Cannot launch Java application. Uncaught exception in main method: java.lang.UnsatisfiedLinkError: no EnetConfig in java.library.path
Troubleshoot: The NI-488.2 Software is not correctly installed on your system. Please follow these steps: 1) Reinstall the NI-488.2 Software. 2) Run the Troubleshooting Wizard again.
Any help would be great. Thanks.
12-02-2014 12:47 PM
How does one go about 'running" NI-488.2 software ?
12-02-2014 02:44 PM
I fixed it, thanks in no part to your completely useless comment
12-02-2014 03:09 PM
You are welcome for your completely useless question.
