USB double output power supply and multimeter with labview support
i'm looking for two products:
1) Power supply with dual voltage output
2) Digital Multimeter
Both must have drivers to be controlled through Labview Via USB interface and must be not so expensive, let's say each of them must cost not over 1k€...
Have you some suggestions?
Thanks in advance.
(3,355 Views)
What kind of signals do you need? There's thousands of power supplies available for all sorts of currents and voltages...
A couple of mA at 5 volts, you could do with a cheap 6008 DAQ.
A couple of kW, you're going to need some bigger equipment.
Define the specs, then start shopping...
(3,346 Views)
