U2722a Keysight source measurement unit
Thanks for your reply!
Just to clarify, were you able to move to higher limits, for example 1mA current limit, in LabView? Any value above 1e-6 gives me "data out of range" error even if I use the boundaries provided in the data sheet (1µA, 1mA, 10mA...).
Cheers
Message 11 of 15
(695 Views)
Given you guys are cornering LabVIEW that the SMU doesn't work only in LabVIEW, were you able to get it to work in other programming languages perhaps like C, C++, C#, Python or VBA? if so, could you please share the working code?
I feel that this has nothing to do with LabVIEW as a programming language and may be a bug in the LabVIEW drivers provided by Keysight, in that case, you can develop using just the SCPI commands using VISA Read/Write (this is an excellent tutorial - https://labviewwiki.org/wiki/VIWeek_2020/Proper_way_to_communicate_over_serial) by referring to the SMU's programmer's manual.
Santhosh
Soliton Technologies
Message 12 of 15
(682 Views)
Hi Thank you for your comments. For me I don't have knowledge with other programming languages, with labview i do and with the drivers that are provided by Keysight it became easy to deal with. Anyway, this is the U2772a driver that I am using with steps I follow. I am using Labview 2019.
Message 13 of 15
(668 Views)
Dear naif64,
Thanks for sharing the VI. Now I understand your previous message about current limit/range.
You went around the current limit ivi bug by configuring the channel as current source during initialization, then switched it to voltage - smart!
I implemented your approach and and it seems I was able to resolve the problem as well.
Thank again for your help
Cheers
Message 14 of 15
(635 Views)
Hi dk 2955
This has been done with the help of the supporting Labview staff.
regards
Message 15 of 15
(620 Views)
