10-15-2022 10:41 AM
Thanks for your reply!
Just to clarify, were you able to move to higher limits, for example 1mA current limit, in LabView? Any value above 1e-6 gives me "data out of range" error even if I use the boundaries provided in the data sheet (1µA, 1mA, 10mA...).
Cheers
10-15-2022 10:00 PM
Given you guys are cornering LabVIEW that the SMU doesn't work only in LabVIEW, were you able to get it to work in other programming languages perhaps like C, C++, C#, Python or VBA? if so, could you please share the working code?
I feel that this has nothing to do with LabVIEW as a programming language and may be a bug in the LabVIEW drivers provided by Keysight, in that case, you can develop using just the SCPI commands using VISA Read/Write (this is an excellent tutorial - https://labviewwiki.org/wiki/VIWeek_2020/Proper_way_to_communicate_over_serial) by referring to the SMU's programmer's manual.
10-16-2022 06:47 AM
Hi Thank you for your comments. For me I don't have knowledge with other programming languages, with labview i do and with the drivers that are provided by Keysight it became easy to deal with. Anyway, this is the U2772a driver that I am using with steps I follow. I am using Labview 2019.
10-17-2022 12:04 PM
Dear naif64,
Thanks for sharing the VI. Now I understand your previous message about current limit/range.
You went around the current limit ivi bug by configuring the channel as current source during initialization, then switched it to voltage - smart!
I implemented your approach and and it seems I was able to resolve the problem as well.
Thank again for your help
Cheers
10-17-2022 07:49 PM
Hi dk 2955
This has been done with the help of the supporting Labview staff.
regards
02-04-2025 09:57 AM
How you solved? Please send the VI.
Many people report the same problem and I do not see one solution !
