U2722a Keysight source measurement unit
Hi I am using the U2722a Keysight source measurement unit to mesuere the output current as the voltage is sweeping between any negative to positive voltages. I download the labview driver. The attached diagram shows the stepes I did to get the process. However, I noticed that when I change the limit current from 1^-6 A, I get the error "1074000000". If the limit current is fixed at its defualt value the programme is working smoothly, but I cannot get currents values higher than the limit one, any advice..?
Message 1 of 20
(2,478 Views)
Hi there,
As I understood, it is noted on the terminal description from the help section that the upper current limit is 1.0uA, therefore setting a current limit higher than the accepted value 1uA will normally result to an error.
Message 2 of 20
(2,420 Views)
Hi and thank you for your reply,
Correct, the 1uA is the default value of the current limit, however it can be adjusted according to the desire value.
I also attach here the vi of the voltage configaration.
Message 3 of 20
(2,407 Views)
Do you mind sharing your Labview file with me as I intend to do the same but I am not as experienced to work with Labview. Thank you so much.
Message 4 of 20
(1,995 Views)
Hi, sure, but may I know what your application is to serve you better? If you are just looking to use I-V measurements, I recommend using the BenchVue USB Modular SMU. It comes with the SMU.
If you are preparing to use FET or transistors, I think you can use U2942A Parametric Measurement Manager Pro Software, this one is the old software from Agilent still can be use under W10. For the program I prepare under LabView there are still some issues as I am also not professional in LabView. but happy to share...
Message 5 of 20
(1,977 Views)
Hi Naifi64
Thanks for your quick response! We intend to characterize FETs, i.e., to use one channel for gating and two other channels for biasing two FETs (constant voltage). Do you think Parametric Measurement Manager Pro Software works with our U2722a (we only work within -+2 V for gating)? Also, do you think your LabView program can work with some tweaks? I appreciate your help and time.
Message 6 of 20
(1,961 Views)
