08-01-2005 03:11 PM
08-01-2005 03:41 PM
08-10-2005 01:23 AM
I am using a similar application, where I need except the data Tx (TxD) also two clocks. Is there a possibility to get out of the 9 pin two other transmission lines?
It's because I am trying to run a 74TTL595 8-bit serial-in to parallel-out controler.
Yariv
08-10-2005 02:20 PM
I might be confused by your question, but are you wondering if the 9 pin line has more than one transmission line? If you could clarify a little bit more for me that'd be helpful. Thanks!
JenK
08-11-2005 01:03 AM
Yes. I need 3 transmission lines out of the 9-pin. The don't have to be paralell.
To overcome this issue I have started to work with the paralell port.
Thanks yariv
08-12-2005 07:50 AM
Hi Yariv,
It sounds like you may have found a solution, but I just wanted to share the following information with you regarding the serial port and what each pin is used for. The description next to each pin in this case would be for a modem connected to your computer:
9-pin connector:
