Trying to connect Keithley 6517 A to Lab View Driver for the device using GPIB to usb Connectiong
I am trying to read data from Keithley 6517A. I am using Agilent 82357B GPIB-USB Interface High-Speed connection in order to read the data from the device to Labview. There seems to be a missing bridge of connection between the Keithley and the program. I already installed the driver for the Agilent 82357B GPIB-USB Interface that came with it and I am using the Vi for Keithley 6517A downloaded from NI. When I select the Visa Resource name the electrometer does not seem to pop up and the error message is given as followed...
Data.vi<ERR>
<b>Reference Not Found:</b> (xBFFC0012) Cannot retrieve user data for the given resource name as there was not data associated with the resource name. Before you can read data, you need to write the user data using the Write Data action of this User Data VI.
Any suggestions or solution
Message 1 of 1
(1,888 Views)
