I have lengthen the VISAt-timeout (20 seconds) and now I can use also longer Trigger-Delays. But now I have the problem, that it takes for this command:
*RST;:CONF:VOLT:DC;:TRIG:SOUR EXT;:TRIG:DELAY 2.5;:TRIG:DELAY:AUTO OFF;:INIT;:READ?;:TRIG:DELAY?;:SYST:ERR?;
9 seconds, although I have only a Trigger delay of 2.5 seconds. The answer for this command is:
+4.88885300E-03;+2.50000000E+00;+0,"No error"
The problem is, that the Function Generator creates a Sinussignal with a frequency of 1 kHz and a Voltage of 8 Vpp. So I should have about 4 V and not only 4,88 mV.
When I use lower frequencies (like 500 mHz) the measured Voltage is higher (almost 4 Volt when I use a delay where a Voltagemaximum should be), but for example I get at a frequency of 500 mHz a higher Voltage with a Triggerdelay of 400 ms, then with a Triggerdelay of 500 ms (which is the Voltagemaximum).
What can be the problem of the very long execution of the command and the strange measured values?
I would be glad, if you could help me.
