03-28-2019 10:10 AM - edited 03-28-2019 10:12 AM
I have a Waverunner8254 scope and I’m trying to do some automation in LabVIEW with it.
The problem I’ve encountered is with sending files to the scope over USB.
I found a solution that works (Another Topic), but it works only to files that are less than around 65k bytes (I could assume 65535 but I did not test exact value).
If I try to send a file which is larger than 65k I get timeout from VISA blocks and I cannot connect to scope again until I reboot it.
Is there some kind of buffer that is adjustable here or maybe I’m missing something here?
I’d really appreciate some help here.
I only have a remote access to this scope so I can't dig into its configuration and the manual does not help as well...
03-28-2019 11:59 AM
03-28-2019 12:16 PM
03-28-2019 04:20 PM
03-29-2019 04:00 AM
Unfortunately splitting the data into two parts did not work even with Synchronous mode on.
It seems like the scope only accepts the first part, and disregards the second one.
I'm in contact with Lecroy support so maybe they will have an answer for me.
As soon as I find something I will post it here so that it would be useful for someone else.
