I have measurement setup with two PT100 resistance thermometers. Thermometers are connected with four-wire configuration to Agilent 34970A (with 34901A Multiplexer Module). So far everything is working fine. 34970A shows right values when set to RTD 4w.
Temperature Data Logging with the Agilent 34970A
I'm trying to use userstep_34970a for temperature data logging. 34970A is connected to computer via NI GPIB-USB-A and communcation between these two works just fine.
Problem is that Configure VI > 'Transducer Type' selection doesn't seem to work. No matter what i select from drop-down listbox, after 'Run/Run Once', for some reason it always sets 'Transducer Type' to thermocouple (J TYPE T/C) in 34970A.
