04-20-2015 04:25 PM
Hi Guys,
i am looking to do a very basic task in labview but i am running into difficulty. i will try to explain as accurately as possible.
I want to create a Digital output which my transmitting circuit is connected to P0.0 in frame 1 that will start a timer when the signal in frame two is received Digital input it calculates a time difference between sent signal and received signal. I have added a while loop that while the condition is not true it continues to check until it is. My vi is below but I cannot get it to work. Please help.
here is the vi hopefully someone can help
04-20-2015 05:53 PM
How accurate of measurements do you need? You will not get anything really accurate using a Windows clock. You may need to set up a counter along with some external circuitry to get what you want.
04-21-2015 03:28 AM
Hi.
My circuits consist of the following.
Tx: LM555 generating a 40kHz which is connected to an AND gate which i was using to start the sequence.
Rx: circuit is connected to an LM567 which hen the PLL detects 40kHz drops the output voltage of pin 8 to 0v.
It is this time between the intial Tx sending and the recieving of the 40kHz pulse Rx that i need to capture.
04-21-2015 03:29 AM
also my NI device is a usb 6216
04-22-2015 07:16 AM
I had a quick look over your code and noticed a few things that you need to implement:
I hope this helps!
04-23-2015 04:59 PM
still having trouble in getting any timing measurement at all from circuits. attached is the latest Vi
