The Basic Serial Write and Read VI is adding FF at the end of every command
HI,
I'm using the basic serial write and read VI for RS-232 communication and at the end of every command FF is added wich is causing problems (I'm communicating with an Actel development board). Is there a way to disable this (and where does it came from)?
I use the following settings:
baud rate: 9600
data bits: 8
parity: none
stop bits: 1.0
flow control: none
termination character: false
Ben
(3,537 Views)
so it must come from the commands you are sending, please publish your vi
greetings from the Netherlands
(3,535 Views)
Thanks Albert for pointing me in the good direction. I was so convinced that it came from the basic serial write and read VI that I didn't look further away. I finally found out where it came from, a leftover from old code that I reused.
Ben
(3,510 Views)
