06-24-2019 06:13 PM
I'm measuring the cooling of a metal part with 4 type K thermocouples connected to the USB-6343 in the SignalExpress software, the signal registered oscillates too much, hence the temperature measurements have noise. I don´t know if it's a configuration problem or electrical noise. Any recommendation to avoid this oscillation problem?
06-25-2019 09:59 AM
A few questions:
06-25-2019 05:12 PM
For the CJC compensation, we are setting a constant temperature of 25 °C, the sampling is every 0.1 s. We´re using SignalExpress.
In the attached image, I show you one of the curves that we acquired
07-02-2019 03:49 PM
